2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
#1349520 03/11/2020 1:30 AM
After driving a few miles, all 4 wheels lock up. Have bled brakes several times, and changed wheel cylinders. No help. Any ideas out there? 1946 Chevy pickup, 1/2 ton..
Don’t know what your running for a master cylinder or brake pedal mechanism but I saw a similar problem on my friends 65 C10. The PO of the truck changed it from a stick transmission to an automatic, he also changed the brake pedal mechanism to a single pedal. The push rod for the master cylinder wasn’t adjusted correctly and when the engine compartment and firewall mounted master cylinder warmed up, the push rod would apply the brakes. Once it cooled off, everything went back to normal. We adjusted the push rod so it had an 1/8” gap between the end of the rod and the master cylinder plunger and it’s worked fine since. Hope this helps.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
After the brakes lock up what happens ,do they release after time . Could be the master cylinder or proportion valve not letting the fluid back .I had this on a old car but only on the front left wheel turned out to be a rubber flex hose you could push the brake and the hose was not letting the fluid back .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
