2 members (Gdads51, 1 invisible),
92
0
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 4 New Guy | | New Guy Joined: Jun 2017 Posts: 4 | Does anyone know if the radiator core support from a '52 would fit in a '55 1st series? | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I suspect it will fit but the 54 55 1st has some different holes for horn mounting I believe. Tim will come in with the absolute answer. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I would not want to venture a guess.
Didn’t radiator dimensions change in 1954? Or, was the mail change the mounting holes for dual horns on the lower forward surface of the frame?
Maybe some one else knows. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Are both trucks same size? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are both trucks same size? Boilermaker82 In each new thread, always indicate the year make model/size of the truck. | | |
