| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Started working on 51 3104 this weekend, hasn't been started for over a year. After the usual shot of seafoam and motor oil in the cylinders in case of stuck rings, cranking with plugs out, etc. etc. I was ready to start her up. My almost 5 Grandson patted her fender and said "come on old baby, fire up". When I was done laughing I put the key in and it wouldn't turn. Trip to NAPA for new switch, came back and read service manual to figure out how to remove the old one. When I pulled the cylinder out inspiration struck! Maybe I can save it. So I cleaned it up and put it back together, it worked and the "old baby" fired up eventually. But the switch is stiff and I'm thinking about pulling it back out and lubing it. White grease, lock ease, never seize, muffler bearing grease. Any suggestions? Thanks.John
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Dielectric grease. It was commonly used in old TV sets for high and low amp switches. Dielectric grease is neither a conductor nor an insulator of electricity. It lubricates, protects against corrosion, and apparently gets out of the way to allow full current to pass between switch contact areas. Use of a conducting type grease for a switch may cause a current bleed, as it contains electrical conducting compounds.
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | duh, I have a tube of that. Thanks Carl. John | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Soak the whole thing in evaporust for a couple days Rinse it well and blast it out with air That stuff is like magic and works okay on aluminum oxidization too.
And it’s not a nasty chemical it’s environmentally friendly depending on the metal being cleaned because it binds to the oxide of the metal So if you clean iron or aluminum you can dump it anywhere If you clean lead parts then maybe not so much -s | | |
