7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51), 130 guests, and 2 robots.
Topics128,109
Posts1,056,267
Members48,439
#1349165 03/07/2020 8:29 PM
when first got my restored 1948 3600 chevy, the master cyclinder reservoir was dry. i filled it up and bled the brakes brakes workd fine for about 3 months. i took it out today and went to stop and nothing, right to the floor, looked and master cylinder needed fluid ( a lot). it filled, hand pump a few times to see if i could get air bubbles in MC but nothing. put the cap back on the MC, proceeded to. bleed the brakes and still nothing. looks like a fairly new MC, does this sound like MC failure????
1948 3/4 ton Chevy Pickup
Did you find a puddle of brake fluid anywhere? It had to go somewhere.
that remains a mystery no evidence that i can see.
Brake fluid doesn't evaporate, so it's either on the floor, puddled up on the frame somewhere or inside a drum...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Does the vehicle have a Hydrovac unit or other vacuum assist ?
no just drump brakes-----
also does not explain why i don't seem to be able to bleed the brakes now. i will check the wheel cylinders , it is my only guess now- leaky wheel cylinder.
Am I understanding you correctly...with a full MC you can't get any fluid to come out of the bleeders. Even if the wheel cylinders are leaking, you should still get fluid out of them when you open the bleeder valve.
Are your brake lines all new or recently replaced (steel and rubber)?
As you said, it's time to pull all four drums and inspect for leaks...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
no i was able to get fluid out of bleeders, with no air. next stop pulling the drums
If the brakes failed and peddle floored, but no fluid loss on the ground. I would look at all 4 corners. What m/c setup do you have? Firewall mounted, under floor mounted? Like previosly stated, fluid went somewhere. If firewall mounted and you have carpet, look under carpet.
it is an under the floor MC, with no visable puddle
Sounds like a bad master. Is there a little rubber boot on the back where the rod enters? If so, peel it back and see if its wet.
Mike
