5 members (Charles in CA, Gdads51, 68ironhead, 2 invisible), 85 guests, and 2 robots.
Topics128,032
Posts1,055,519
Members48,425
#1348714 03/04/2020 12:05 AM
Are the bolts that bolt the generator to the bracket on the block shoulder bolts? The full thread bolts put on by P.O. seem sloppy in there. Thanks Steve
Sir Searchalot
Sir Searchalot
Originally Posted by Steve1940
Are the bolts that bolt the generator to the bracket on the block shoulder bolts? Thanks Steve
No
Ok Thanks .
Original bolts have a long area that is not threaded.
The only part that is threaded is basically what extends out of the bracket.
My Blog
Sir Searchalot
Sir Searchalot
3 short bolts. 2 on gen ears, 1 on adjusting strap.
Thank you I will get it done.
