7 members (Woodcmiami, LAROKE, Hotrod Lincoln, Southerntruck, MNSmith, gswbbc, 1 invisible),
117
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Are the bolts that bolt the generator to the bracket on the block shoulder bolts? The full thread bolts put on by P.O. seem sloppy in there. Thanks Steve | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Are the bolts that bolt the generator to the bracket on the block shoulder bolts? Thanks Steve No
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Original bolts have a long area that is not threaded. The only part that is threaded is basically what extends out of the bracket.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 3 short bolts. 2 on gen ears, 1 on adjusting strap.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thank you I will get it done. | | |
