5 members (klhansen, HandyAndy, Hanks custodian, Hugh63c10, dt235sd), 66 guests, and 1 robot.
Topics128,092
Posts1,056,043
Members48,433
#1346435 02/14/2020 1:57 AM
I've struck out on getting the firewall piece so far, but it looks like LMC has a reasonably priced repro.
https://www.lmctruck.com/1960-66-ch...n2OxByvKGWHUtMxoO-zg9naQUtxoCbzsQAvD_BwE
Has anyone bought this panel and fit it up yet?
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
I went to salvage and got mine but that was thirty years ago. Wish you luck.
My 1961 Chevy Pickup Truck
In the GalleryMy Webshots Shoebox
I had to drill through every single spotweld to remove the upper cover in order to get ready to swaps trans (we could not get to the bell housing bolts from the bottom) GM used 28 spot welds in less than 2 feet, I kid you not. I'm using caged nuts in 6 locations to fix in place and double sides tape in between those. I had to drill through each one with a 1/8" bit then a step drill, that was some tough metal, burned up or wore out a spotweld cutter. The new repop fits well. The current trans is a 4 speed hydramatic. we are putting in a 700R4. I have the special block adaptor that allows you to mate up another trans.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
That's what I did, but that was nearly 20 years ago. The wrecking yards I used to go to have all either closed and gone out of business or stopped carrying parts for our old trucks. I haven't found a local yard with anything older than 2000 for a while.
Originally Posted by Modelman
I had to drill through every single spotweld to remove the upper cover in order to get ready to swaps trans (we could not get to the bell housing bolts from the bottom) GM used 28 spot welds in less than 2 feet, I kid you not. I'm using caged nuts in 6 locations to fix in place and double sides tape in between those. I had to drill through each one with a 1/8" bit then a step drill, that was some tough metal, burned up or wore out a spotweld cutter. The new repop fits well. .
Those spot welds were a PITA!
Previous owner swapped out the 3 on the Tree (low hump) for an SM420 4 speed (high hump). Bugger didn't change the hump. He just screwed some sheet tin over the whole works and called it good. What a nightmare!
Plenty more wrong with his work, but that's another story.
Parts can be found. It's a pain, and it may require shipping, but they are still out there. The back half is easy. Nothing to change there.
