1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#1309447 05/03/2019 11:55 PM
I’m not very good at tire sizing. I have 2 wheels already for the back of the truck. 15x8 6x5,5 OS -6, BS 250, CB 4.28
I need a front wheel 15x7 6x5.5 but I don’t know what offset and back spacing to get. I’m running drum brakes all the way around. Oh and this set up is going on my 1957 truck.
Thank you for the help
Chevytruckdaddy
Not exactly sure what you asking. You have rear wheels but need a set of tires for those wheels? Something doesn't add up with your wheel lug count and spread. Typical Chevy wheels would be a 5-lug with a 4.75 pattern. Your numbers are 6-lug by 5. Are you running different axles under your '57?
They do have mock-up wheel devices out there just for your situation, although they are expensive and typically a one time expense. I would seek out a reputable tire service center in your area and discuss your concerns and let them recommend a wheel.
Apache1, 1/2 ton trucks use 6 lug wheels not 5 lug. FYI
I stand corrected.
I have a set of wheels and need a set of wheels for the front with the right off set and the right back spacing so the I’m not loosing the ease of steering. Does this make sense?
Yes 1/2 ton Chevy’s have 6 lugs.
Thank you everyone
Chevytruckdaddy
Maybe these will work for the front?
Chevytruckdaddy
Backs I already have
Chevytruckdaddy
The backspace s too deep for the front with those wheels. The wheel would rub the drag link on a left hand turn. What you want is a 3.5" backspace for a proper fitment. on a 7" wheel, that would work out to a 0 mm offset.
Bill Burmeister
Ok awesome, I’ll look for those specs tomorrow. Thank you.
Chevytruckdaddy
Rusty Nuts
Rusty Nuts
These are the only modern rims I found that work the OEM 6 lug wheels and still miss the OEM steering linkages.
AM20761B from etrailer
Dexstar Steel Mini Mod Trailer Wheel - 16" x 6" Rim - 8 on 6-1/2 - Black
Rustbucket Ranch
Rustbucket Ranch
Those 8 lug Dexstar rims will have a hard time bolting up on a 6 lug truck wink
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
