9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 6 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 6 | I am in the process of restoring a 1946 chevy pickup my dad had. I have discovered that the truck has a 1947 bed and rear fenders. This is likely why the existing running boards have been spliced and the front does not match the rear ribs. Can running boards for a 1947 be made to fit this truck. | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | I had a question about running boards about a week ago. One of the bolters answered me right away. He knows his boards. it was tclederman.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe someone will respond who has used/adapted the later running board? | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Greetings Corvette Bill. This sounds like it will need to be fabbed. Since both ends of the running boards bolt to the fenders, and the fenders are different from 46 to 47, (and as you discovered the rib count is different), you'll have the make something work. If you're going to keep the 47 rear fenders, maybe you can just clean up the splice. If you go with rear 41-46 rear fenders, maybe you can find the rear part of that year boards and splice them in. Just my opinion. Good luck1
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have some unknown full length running boards, I could take some px if you would like.
Ed
