| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 45 | Hello, Does anybody know where I can purchase a mirror bracket that goes into the door pin for a 1946 Chevy 2 ton truck? Any help is grateful ,or will I have to fabricate something? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think JimCarter has those.
Ed
| | | | | Joined: Dec 2006 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 45 | | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Classic Parts has them. Mirror Arm
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2006 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 45 | Thanks, But not the same. This was more or less like a c bracket that the extendable arm bolted to . | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | I believe I have a spare one. Will see if I can locate it today. The aftermarket world seems to ignore us Bigbolt guys. | | | | | Joined: Dec 2006 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 45 | Thank you! And yes, they do ignore us. I need a new floor mat, do you know if the ones they sell will fit the big trucks? Thank you again, Jim | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | Yes the floor mats for the little trucks are the same. You may need to make some different cutouts for PTO levers or such. I had a terrible experience with a reproduction floor mat. It crumbled to dust after only two years in service. I would consider getting one of the repros from the common vendors a risky endeavor. I found that tractor supply sells a very inexpensive 1/4 thick rubber mat to worked very well and at small fraction of the reproduction mat price. | | | | | Joined: Dec 2006 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 45 | | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | Found the mirror bracket last night and took a couple of images. Have to leave for work early this morning so no time to upload images here...stay tuned. | | | | | Joined: Dec 2006 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 45 | | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | Please take your final deal to private messages, buying and selling is not allowed on the tech forums. | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | | | |
