1 members (Forty9),
134
Mod | | | Forums66 Topics128,132 Posts1,056,385 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | I have a 2001 5.3 Vortec engine with a 350 turbo (year unknown) in my 49 pickup. The transmission is leaking I believe from the pan gasket and the shifter shaft seal. I am not having any issues with the transmission and it shifts fine. I just got this truck about 4 months ago so I want to take it in and have the transmission serviced. I did this on a car some years ago and they flushed the transmission out and it never did shift right after that. I had to have it rebuilt. I fear the same thing may happen again. I was thinking of just having the fluid, filter, & gaskets changed along with the shifter shaft seal. What are your thoughts? | | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | What's the condition of the fluid on the dipstick? Unless it's dark, gritty, or has a burned odor, leave well enough alone. Since it's impossible to get all the old fluid out because there's no way to drain the torque converter, stirring up things by dropping the pan and doing a filter swap doesn't accomplish much. The only thing "flushing" does is flush some of your money down the drain, and it could cause other problems. Jerry
| | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | What's the condition of the fluid on the dipstick? Unless it's dark, gritty, or has a burned odor, leave well enough alone. Since it's impossible to get all the old fluid out because there's no way to drain the torque converter, stirring up things by dropping the pan and doing a filter swap doesn't accomplish much. The only thing "flushing" does is flush some of your money down the drain, and it could cause other problems. Jerry I agree..... I really hate to disturb anything but I need to get these leaks stopped. I've been using DEX/MERC Transmission Fluid and it's reddish in color. Not gritty, or any odor. The PO said that's what they did was just drain a replace the fluid and filter but you know how that goes. I believe nothing I hear and only half of what I see. | | | | | Joined: Feb 2020 Posts: 4 New Guy | | New Guy Joined: Feb 2020 Posts: 4 | I build transmissions for a living and deal with the leaks all the time. The shifter shaft seal is a common place for leaks to occur. It is relatively easy to fix. Disconnect the linkage from the shaft, purchase a new seal and the seal remover/ installer tool at your local auto parts store. The tool has a tapered pipe that threads into the old seal. You then use the bolt in the kit to pull the seal/ tool out of the case. Then use the other part of the tool to tap the new seal in place.
As for the pan gasket leak, its probably a warped pan rail due to over tightening. You can remove the pan and straighten the rails and reinstall with a new gasket. If your pan doesn't have a drain plug, you can add one while its off. There are kits available to do this as well. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Do only what is necessary to repair the leaks. Many hundreds of thousands of fluid/filter changes have been done to every make and model of automatic transmission without any ill effects. As Jerry said you cannot get all the fluid out so some dirty fluid will remain no matter what you do. Nice red non smelly fluid is a plus as a starting point.ðŸ›
| | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | Yeah I'm thinking change fluid, filter, pan gasket, and seal and call it a day. | | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | Back in the dark ages, torque converters and fluid couplings could be disassembled and cleaned. Some converters also had drain plugs. It's possible to get more fluid out of a transmission by disconnecting one of the cooler lines at the radiator and running the engine to pump most of the fluid out, then refilling with fresh fluid. That's what some franchise shops call a "flush". As long as you don't let the pump run dry long enough to damage it from lack of lubrication, that's one way to pump most of the old fluid out. Some transmissions need to be shifted to "drive" to get the cooler circuit working. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm for dropping the pan & replace the seal. Even some new fluid will keep the seals soft & the trans. clean.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | I'm for dropping the pan & replace the seal. Even some new fluid will keep the seals soft & the trans. clean.
George Yup. That looks like the game plan. | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Have them put a good magnet in the pan & fill w/ Dexron VI would be my advise.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | Have them put a good magnet in the pan & fill w/ Dexron VI would be my advise. I've been running Castrol Transmax DEX/MERC | | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | Well I talked to some of the local boys about what transmission shop treats us AD owners the right way. Made the call today to get a price on fluid change (NO FLUSH OUT), shifter shaft seal replacement, filter, and gaskets. $150 to $200. Thought that was pretty reasonable. I just hate leaving the truck over night. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Leaking pans gaskets are a constant problem with older trannys that someone has messed with. Over tightening the pan bolts will bite one every time. Check to see if the pan bolt holes are convex on the gasket side. If so, hammer and dolly them flat with the pan gasket surface. As stated, a threaded bung hole is a good idea. Does anyone have a fix for the speedo bullet o ring. I’ve replaced the o ring and remade/modified the cheesy bracket that holds the bullet in. Still get a drip now and again.
| | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | Does anyone have a fix for the speedo bullet o ring. I’ve replaced the o ring and remade/modified the cheesy bracket that holds the bullet in. Still get a drip now and again. Try this stuff. It's not like RTV silicone and the other "rubber" sealers- - - -it actually cures to form a gasket. Coat the area of the "bullet" outboard of the O ring after giving the trans case and the insert a good cleaning with solvent. I've used it on places like 18-wheeler drive axle flanges and other hard to seal areas with very good results. https://www.permatex.com/products/g...ealants/permatex-anaerobic-gasket-maker/Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a tiny seal where the gear goes into the bullet. It seems the replacement seals are not very good. The best way to service one is to buy a new whole new bullet assem. They are about $7 & are readily available. Make sure the shaft of the gear is not rough. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
