4 members (49nut, Steelonsteel, klhansen, Shardean), 73 guests, and 4 robots.
Topics128,022
Posts1,055,376
Members48,420
#1346537 02/14/2020 9:29 PM
I noticed my heater only runs when the truck is moving. It will not run when at idle. My wiring is most likely the problem, but I'm looking for suggestions. Thank you from a1958 Chevy Grumman.
1958 Chevy Grumman Olson step van
Chaz 58 #1346542 02/14/2020 10:32 PM
1958 12v electrical system?
Does this happen when the lights are off?
What electrical devices are on?
Chaz 58 #1346568 02/15/2020 2:17 AM
Is this a Fresh Air (Deluxe) or a Recirculating heater?
What test methods have you used to confirm the fan only has voltage when the truck is moving?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Chaz 58 #1346648 02/15/2020 6:50 PM
This could be a rusty armature or worn brushes problem in the fan motor..
What happens is the armature gets rusty and the brushes can't make good contact with the armature.
With the truck moving, there is enough vibration for the brushes to make good contact with the armature.
To test this theory, turn on the fan and tap the fan motor with a hammer, see if fan motor starts to spin.
If it spins there could be two problems, the brushes are worn or the armature is rusty.
The fix is to ether replace the fan motor or sand down the armature with emery cloth to de-rust.
If brushes are worn you could replace brushes.
Note: Some fan motors are hard to take apart.
Chaz 58 #1346661 02/15/2020 10:00 PM
Crusing in the Passing Lane
While spending the labor to take it apart, might be worthwhile to replace the motor. Most are available.
Ed
Chaz 58 #1347013 02/18/2020 2:36 PM
V
VEW Offline
V Offline
I have an Evans heater in my 55. Shows 6v on the case, so I disassembled it only to find out someone already put a 12v in it. Please easy to do. Just check your wiring.
Parts are available through Mill Supply.
~ Victor
1957 3100 - moved on
