5 members (Greg_H, GMCJammer51, HandyAndy, Phak1, 54farmtruck), 54 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
I was lucky enough to acquire a very rare Eaton Positraction Differential unit (thanks to Jeff @ redneck restorations). These were available in 1960, 1961 and 1962 1/2 Ton Chevy trucks. Late 1955, 1956, 1957, 1958 and 1959 Chevy Trucks share the same rear end and one of these posi units is a DIRECT bolt in for any of the listed trucks if you can find one. The unit was in good condition and was a pretty straight forward swap. I had a 3.90 gear ratio and opted to stick with that because I am going to eventually install a Tremek TKO 600 5-speed which will make it very driveable and very peppy since there is a 454 LS6 in front of it.
All the information you need on the rear end and Eaton Posi unit can be found in the 1960 Chevrolet Truck Shop Manual. This will apply to ALL 2nd series 1/2 Ton Trucks 1955-1962.
I did this more as an experiment because my intention is to keep the truck as stock as possible and did not feel like changing the entire rear end for a 12 Bolt. The original Axle is very beefy 9.3" Ring gear on a 12 bolt carrier (even tho the rear cover is only 10 bolts I assure you it is a beefy 12 bolt inside). The only drawback to these older rear ends is the spider gear do not use thrust washers. Basically what will / can happen is that when the spider gear or house start to "gall" then it is game over for the Differential Case. The gears were not cut with enough clearance to add thrust washers. Well atleast any thrust washers I had on hand. Later model 12 bolt thrust washers fit on the cross shaft but when assembled the gears are too tight and will not function properly. I suppose a machinist could fabricate some very thin thrust washers that could "possibly" work but that is out of my league and this Truck is far from a daily driver so it really is no big deal. The later model rears and the addition of the thrust washer are the main reason they are rock solid axles.
I will add some pics to this thread and hopefully it can be useful for someone in the future.
I recommend to watch this video and all 5 parts of it, I think there is a Part 1, Part 2, Part 3, Part 3.2, Part 4. This is a very similar axle and setting the preload on the carrier and backlash is very informative. The whole video is unbelievable and this guy is a master and knows his stuff. His name is John and it is from Weber State University and they should be credited and commended.
Here is a link to a PDF from ClassicChevy.com that is very similar to the procedurre I did and can be useful as well.
https://www.classicchevy.com/assets...OSITRACTION%20CARRIER%20INSTALLATION.pdf
Pics can be viewed in this link. Some are of the Posi and some are the original non posi
[img]https://photos.app.goo.gl/2DgEhCwi3X8cztFh7[/img]
Frank
1948 5 Window Chevy 3100 an absolute rescue that is now back on the road
1953 Buick Super 1 family owned since new
1956 3200 Big Window
1985.5 Mustang SVO
1986 Mustang SVO
Someone talented with a die grinder could probably fabricate a flycutter that could be used to deepen the counterbores in the carrier to accommodate the thrust washers, which would be well within the capabilities of a good tool and die maker.
Can you still get clutch plates, etc for it for it?
BC
1960 C60 pasture art
I don't think they are made by any aftermarket company BUT I believe that you can use clutches from other applications and can cut the "ears" to fit like the originals. The main issue is making sure that if you use "other" clutches that they would have to be equal in thickness when "stacked" as the clutch pack to the original clutch pack. There are certainly other clutch pack kits that have the same dimension as these clutches regarding diameter and inner diameter. I think many Eatons are the same size. All the clutches do is grip each other and the "steels" that are in between.
I think someone who has plenty of spare parts from different brands of carriers and axles could mix, match and modify to get something to work, actually there is no doubt in my mind that it could be done
Frank
1985.5 Mustang SVO
1986 Mustang SVO
