0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13463 05/07/2003 7:02 AM | Joined: May 2003 Posts: 7 Member | | Member Joined: May 2003 Posts: 7 | my darn fuel pump on my 2354 has gremlins and it wont pump fuel past the outlet side of the pump | | |
#13464 05/07/2003 3:41 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Is it a newer fuel-pump? - Do you have a filter between the tank and the pump?
#13465 05/07/2003 3:46 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you have good flow entering the pump, then it's time for a replacement from your local parts store. If the flow isn't good, check at the tank. It could be a plugged line or too much junk in the tank.
Fred 52 3600 69 C-10
#13466 05/07/2003 5:13 PM | Joined: May 2003 Posts: 7 Member | | Member Joined: May 2003 Posts: 7 | i was thinking it might have a bad diaphram in the pump it is one of those gm pumps that can be disasembled | | |
#13467 05/07/2003 5:17 PM | Joined: May 2003 Posts: 7 Member | | Member Joined: May 2003 Posts: 7 | i am not running the tank in the cab any more i put a 35 gallon winnabago tank on the frame on the drivers side and on top of that i am sucking out of a jerry can that is sitting on top of that and the fuel line is new | | |
#13468 05/07/2003 7:46 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can rebuild the pump, if you can locate the kit. I don't think they've been made for years. Last one I bought was $30, I think the one with the vacuum pump was about $50.
#13469 05/07/2003 7:52 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Last year or was it 2 years ago I replaced my fuel pump for less then $20.00 at the local mom and pa parts store. It was a cater and other then not have the AC logo it was identical to the one that I replaced. If you need the part number email me and I will get it for you tonight.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#13470 05/08/2003 5:46 AM | Joined: May 2003 Posts: 7 Member | | Member Joined: May 2003 Posts: 7 | well i took care of my problem i put an electric fuel pump on it. it came off of a chevy luv so i figures it is still chevyi kmow it isnt original but i am looking for usability | | |
#13471 05/08/2003 8:01 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Weren't Chevy luv trucks made by Isuzu? | | |
