7 members (2-Ton, Shaffer's1950, Otto Skorzeny, Gdads51, stoveboltgator, klhansen, Rusty Rod), 91 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
#13463 05/07/2003 7:02 AM
my darn fuel pump on my 2354 has gremlins and it wont pump fuel past the outlet side of the pump
#13464 05/07/2003 3:41 PM
Is it a newer fuel-pump?
Do you have a filter between the tank and the pump?
#13465 05/07/2003 3:46 PM
If you have good flow entering the pump, then it's time for a replacement from your local parts store. If the flow isn't good, check at the tank. It could be a plugged line or too much junk in the tank.
Fred
52 3600
69 C-10
#13466 05/07/2003 5:13 PM
i was thinking it might have a bad diaphram in the pump it is one of those gm pumps that can be disasembled
#13467 05/07/2003 5:17 PM
i am not running the tank in the cab any more i put a 35 gallon winnabago tank on the frame on the drivers side and on top of that i am sucking out of a jerry can that is sitting on top of that and the fuel line is new
#13468 05/07/2003 7:46 PM
You can rebuild the pump, if you can locate the kit. I don't think they've been made for years. Last one I bought was $30, I think the one with the vacuum pump was about $50.
Fred
52 3600
69 C-10
#13469 05/07/2003 7:52 PM
Last year or was it 2 years ago I replaced my fuel pump for less then $20.00 at the local mom and pa parts store. It was a cater and other then not have the AC logo it was identical to the one that I replaced. If you need the part number email me and I will get it for you tonight.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#13470 05/08/2003 5:46 AM
well i took care of my problem i put an electric fuel pump on it. it came off of a chevy luv so i figures it is still chevyi kmow it isnt original but i am looking for usability
#13471 05/08/2003 8:01 AM
Weren't Chevy luv trucks made by Isuzu?
