2 members (Peggy M, crenwelge), 173 guests, and 3 robots.
Topics128,077
Posts1,056,015
Members48,433
I have a 1965 k10, I'm looking for the power steering bracket to swap a 1984 power steering box. Does anyone make a bracket for the 4 x 4 ?? I know most make it for the 2 wheel drive.
Sir Searchalot
Sir Searchalot
Here is a Kit and explanation from CPP. You can see that it is nothing more than two plates. Not much difference in the box mounting for 4wd.
I have made my own mounting plate for a 56 GMC 4X4 conversion and I also now have a 1960 GMC 4X4 with a previous owner installed box. Owner fabbed/mounted. Both use the Saginaw box. It really is not a major effort. Just involves mocking up the box, designing a plate and arrange the steering shaft hook up. Then find brackets for mounting the pump.
The difficult part is the pitman arm. My 1960 uses a welded (fabbed from two) arm. Once the box and plate are mocked up (NOT BOLTED UP OR WELDED), the search for a pitman are begins. If one is not found, make one.
There are "drop" pitman arms available and I think adjustable arms.
You can, of course, buy the CPP kit or equivalent from the aftermarket. I do not know if the pitmans available will fit. Maybe a member here has found a pitman for 60-66 4X4 or other.
I will post a pic of the 1960 if you decide to follow thru with this effort.
Thanks would definitely appreciate any help, pics would be great. I have an 84 k10 box, drag link, and front diff..
Sir Searchalot
Sir Searchalot
If you are putting the 84 diff on, then you may have it made. I used a 1980 front diff with matching PS box on 1956 Frame. Used some metal I had to make adaptor plate(s). First 4 pics.
The last pic is the "overbuilt" box mount on the 60 4X4. This is not necessary but I left it alone. I probably should cut off half of it.
Sir Searchalot
Sir Searchalot
Too late to cut it off now.
Thanks I really appreciate it.. hey what size rims and tires are u running??
Sir Searchalot
Sir Searchalot
31/10.5/r15
