3 members (Rusty Rod, Hanks custodian, Samantha), 95 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
#1343132 01/21/2020 6:24 PM
Went to change gear ratio on my 41 rear end. Turns out that everything from and including the output shaft flange to rear Spyder gears are worn out. None of the OTC dealers have anything to help. I am looking for suggestions on either parts to keep semi stock or the best suggestion to upgrade.
It helps if you tell us what size/series truck you're working on...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
We need more info to be able to help. Is your truck 1/2, 3/4, 1 ton, or 1.5 ton? How many lug nuts per wheel?
The truck is a 1/2 ton AK, 4 speed, with GMC 228 engine. I was, am trying to change the gear ratio for 411 to 355./
Crusing in the Passing Lane
Probably any '41 to '47 at least axle will fit, however, it might be less expensive to just get a whole new rear rear end. Not many will stock the required parts.
Ed
What I am looking for is information and parts to repair a worn out drive line. I need a output flange, spyder gears, etc... or a complete more modern replacement.
Y
Olddog
Olddog
Y Offline
I have a complete rearend out of a 48 GMC 228, 4speed. E-mail me at [email protected], with questions, if at all interested.
