11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible), 72 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#134491 06/09/2006 11:52 PM
How difficult would it be to put a 1965 270 gmc into a 1950 chevy pickup? How would it compare to a 292?
#134492 06/10/2006 1:35 AM
Impossible. GMC didn't make a 270 in 1965.
Find a '62 or earlier GMC 270 and it will bolt up to you existing bellhousing in your '50. You'll have to use the GMC flywheel.
The front mount is a little different in that the motor is longer.
Check the Tech Tips link at the top of this page. The story about swapping in a 302 will give you most the details you need. The 270 and 302 are almost identical externally.
