3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
1950 suburban
235
Alt with 12v
Foot start
Classic parts wire harness
Finally got my wire harness in. Everything is good except that when I switch the key to ignition position, I can hear my starter turning....
Now, when I got the harness, it said to connect the side terminal on the starter switch to + on the coil. I had previously just used the top post to coil.
The switch was original so I took it off, cleaned it put it back on. I dont know if I did something wrong in the reassembly of the switch to cause this???
I really have no clue.
-Cody
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
How is this happening if you have a foot start pedal?
Make sure you haae the spring on the foot start linkage.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Starter doesnt engage flywheel, just hear starter spinning. Not an engine turning sound, just the starter running.
Defenitly not the foot start linkage.
Fixed it... small metal strip on side terminal of starter switch bent down keeping contact with the starter post.
Gotta love a simple fix. drive
Good detective work!
Another quality post.
Real Trucks Rattle
Yeah, it was all going good until my new temp gauge started leaking fluid.
