Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Oswald, DHedrick, BC59, Otto Skorzeny), 179 guests, and 2 robots.
Topics128,281
Posts1,058,485
Members48,490
#1344311 01/30/2020 6:10 PM
Has anyone used a 57 chevy passenger car rear end in their 55 2nd to 59 chevy 3100. I believe the passenger car rear is 2 inches shorter drum to drum . I have one available to install in my 56 3100 stepside and wondered if it would work without clearance problems wheel width etc. I am going to use rally wheels Thanks for replys
Bump
Since no one has responded it might be time to break out the tape measure and see it the two rears are the same width wheel mating surface (WMS) to wheel mating surface (WMS)...
The spring perches might need to be relocated as well because of pinion angle and/or spring width...
Let us know what you find!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
There are also offset wheels available from varios venders if you find that being the only deal breaker.
I think the car rear end has the spring mount on the bottom of the housing , and the truck mounts on the top.
Tommy
59 apache 1/2t
261 short stepside
The original truck rear is 62 inches flange to flange and the 57 pass car rear is 60 inches flange to flange. Just wanted to know if anyone here has done this swap with this rear.
Sounds like it could be a great experiment!
Assuming it's a 55p differential instead of a 55t, the ring gear is a bit smaller, but doesn't sound unreasonable when you look up ring sizes in other trucks.
Looks like there's a wonderful variety of ring & pinion ratios currently marketed for the car axle instead of just 3.38 for the 55t.
https://www.drivetrainshop.com/GM_55P_55T_s/106.htm
'59 Chevy Suburban, NAPCO
