4 members (Cletus1950, Uncles51, dt235sd, Gray_Ghost), 106 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
I see classic parts offering a 3 connection terminal strip and a 4 connection terminal strips for the headlights on the inner fender.
What is the difference? ...
(Other than one extra terminal)
Cody
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Stock on your truck would be 3 terminals. High beams, low beams, and parking lights.
4 terminal strips could be used for turn signals (dual filament bulbs in the parking lights.)
Don't know if some (later?) trucks came with 4-terminal strips.
[on edit] Apparently 54-55 1st came with one of each. Don't know what the extra terminal was for. Link
[on edit again] Found a '54 wiring diagram. the 4th terminal was for the horn. (mounted behind the grille?)
In 1954, there were 3 terminals on the driver's side inner fender and 4 terminals on the passenger's side inner fender.
The 4th terminal is for the horn, which got moved "up front" in 1954.
1954 truck wiring diagram/information.
I was editing when Kevin "beat me to it".
Thanks, Kevin
Tim
Should we be keeping score? wink
You beat me to a link earlier today. So as far as I know (at least for today) were tied at 1 each. grin
