3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#1343190 01/22/2020 3:36 AM
I have a 49-3100. What is everyone using to lubricate the hood hinge coiled spring? And is there any trick to separate the spring to get the lubricant in?
Motorcycle chain lube is messy, clings, and lasts a long time. Lower the hood till there is just room to reach your arm under and the spring is stretched.
Evan
Food for thought. I lubed my hood hinges and springs on 51 Chevy 2dr sdn about 5 years ago. Cant remember what i used. Maybe wd40 or 30 weight, whatever. Well it worked, so good that the hood opens nice, quiet, and smooth. But now when fully opened it sags down just enough that the gouges on my head from the corners remind me how much i really didnt mind the stiff movement that kept the hood up a tad bit higher. Use caution....lol
Ex Hall Monitor
Ex Hall Monitor
Oiling the hood hinges were once part of a regular oil change. We just used motor oil in a small pump can. A couple of drops on each wear point.
The Tri-flow works well too.
7
7 Offline
I'm with coilover, I use motorcycle chain lube when I want a non-dripping heavy lube.
FrankH7 has the correct idea for me, in Florida sand gets in everything, a dry lube or Tri-Flow works well.
back yard wrench turner
I like to lube with Fluid Film. https://www.fluid-film.com/
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
