Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Gdads51, KEVINSKI, 52Carl, Peggy M), 588 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
Hi all. New to the site. I apologize if this has been discussed but I'm still learning the ropes here. I have a 1957 GMC all original parts truck that has been sitting for many years. The 347 pontiac motor has a ton of cracks in the block. The truck 347 motor is hard to find and extremely expensive to buy. The rebuild kit is crazy priced. So Im looking for opinions on pontiac V-8s that will bolt up to the original manual transmission, column shift. Thanks for any thoughts.
Butch
PONTIAC 389 Early one will bolt right in . Late 50's very early 60's 389. even those are getting hard to find. good luck hunting
!956 Gmc Napco 4x4 Factory line built .
Carburetion specialist
There is an 8 1/2 x 11 by maybe 3/4 of an inch paperback which, after reading, you will move to your "required reading" library section.
I don't remember the exact name, but close to "Pontiac Performance - 1955 to 1979". The author is Pete McCarthy.
EDIT: Didn't realize they were this pricey, and you might find a used one, but here is an ad with a picture:
Pete McCarthy book
Jon.
The Carburetor Shop
There was a "1958-only" 370 cubic inch engine that would probably be a bolt-in swap, but those are likely to be harder to find than a 347. Some versions of that one made 300+ HP.
1 Offline
I've seen GMC's with Olds motors in them too. That might be an option. The BOC bell housings of that era were all the same so you could bolt up an olds or even a Cad for that matter, though that wouldn't appear stock. I once had a 57 Pontiac with a real fire-breather 347 in it. I had no idea that they had become so expensive.
1951 3800 1-ton
In the DITY Gallery
I believe that Pontiac's reverse flow cooling ended in 1959. 1960 and up used a conventional cooling system and a totally different water pump.
Are your '57 heads useable?
5 Online: Content
If it were me, and I could find one, I'd put a Buick Nailhead in it. I wouldn't go with the 322 Nailhead which was used in big GMC trucks in that era. I'd go with a mid-sixties 401 or 425 cu in Nailhead.
Crusing in the Passing Lane
Not sure if all nailhead cranks were drilled for pilot bearing, best to check first.
Ed
Thanks. I have heard that on the 389. Leaning to that option if I can find one
Good tip on the book. Thank you
I'm not sure on the heads condition yet. I havent removed from the block. If I dont see visible cracks I'll take in to gave cleaned and penetrant inspected.
Thanks for all the replies. I'll take a look at these options.
I believe the 1960 389 is a direct bolt in including front motor mounts and does not have the reverse flow cooling. Later 389s I believe you would have to change the timing cover for the front mount. At least that is what I have been told in my search for a '55- '60 Pontiac motor.
I invest my money in precious metals, mostly rust!
Thanks I will be pricing them out.
There is a 1956 complete Pontiac engine listed on Seattle Craigslist for $750.
not mine
If you need more info on the GMC truck Pontiac engines you may want to look at pontiacsafari.com for a lot of good material.
https://www.ebay.com/itm/1960-PONTIAC-389-COMPLETE-ENGINE-HYDRAMATIC-BONNEVILLE-VENTURA-CATALINA-ENGINE/293038460612?hash=item443a740ec4:g:GV4AAOSw4eNcqUmP
not mine
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.321s Queries: 14 (0.117s) Memory: 0.6870 MB (Peak: 0.8111 MB) Data Comp: Zlib Server Time: 2025-09-21 23:11:07 UTC
Valid HTML 5 and Valid CSS
