| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Is there a steering box similar to the stock one that uses less turns 'lock to lock' and looks like the original one?
I just read the thread on steering columns that look the same and wondered if I could find a manual box and column that uses less than 5 turns lock to lock.
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | factory is 4.5 (i believe) and yes you can get a 3.5 lock to lock. unsure if it looks similar to stock though... i'll try to find a link to post in a minute | | |
