3 members (Rusty Heaps, FAST55, Otto Skorzeny), 59 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#134262 04/26/2006 6:03 AM
Is there a steering box similar to the stock one that uses less turns 'lock to lock' and looks like the original one?
I just read the thread on steering columns that look the same and wondered if I could find a manual box and column that uses less than 5 turns lock to lock.
factory is 4.5 (i believe) and yes you can get a 3.5 lock to lock. unsure if it looks similar to stock though... i'll try to find a link to post in a minute
i dont think you will find a manual one but here is a power steering pump quick ratio and a picture of it
http://www.classicperform.com/Store/1947_59_Trucks/CP7501V.htm
