4 members (51 3804, jmmmn37, Wayne67vert, 1 invisible), 109 guests, and 2 robots.
Topics128,260
Posts1,058,322
Members48,485
I have a 1957 Chevy 1/2 ton NAPCO tuck. It has a 1965 Chevy 348 "W" engine installed. Not being satisfied
with the torture that install inflicted, I'm installing power steering and an IDIT column. I'm using a CPP steering
box (part of their power steering install kit). My pickup was not an original NAPCO, I installed the NAPCO
components myself.
My question is this: my truck has appears to have large turning radius (I think it turns the same amount in either direction although
I never really tested that). I'm wondering if I have the wrong drag link. Mine measures 17 inches which I think is the normal length.
The Pittman arm is located approximately 30 degrees (downward) to the back of the truck when the steering is centered.
If I had a shorter drag link, the Pittman arm could be mounted in a vertical position. Or is this the way it should be?
Thanks for your help.
don
I have seen one '57 NAPCO. It came from the factory with the riveted on transfer case crossmember. The pitman arm was clocked exactly as you describe that yours in clocked.
I am suggesting that would be correct for a '57 NAPCO.
You can probably expect to lose some turning radius with the power steering upgrade, BTW.
Don, this is a 1 ton with the CPP kit utilizing the factory column. Drag link is 17” and pitman is slightly to the rear just off 90 deg. This is a 1 ton but I believe my 1/2 tons are the same. I’ll try to get out this weekend and snap pictures. Pat
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
FYI:
Thanks for the replies, very helpful. I did order an adjustable drag link, so when it arrives I will give that a try.
However, I probably will only try it in the garage with the front end raised. Right now we are getting a lot of snow
here in Minnesota and I don't take my truck out in the winter unless the roads are fairly clear (odd, I know, since it is a 4WD,
sort of a rhinestone cowboy mentality I guess).
don
Is your steering arm straight or curved towards, the front?
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
Crusing in the Passing Lane
Donsz, Salt is the real reason, no doubt.
Ed
