7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible), 106 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#1342067 01/14/2020 3:51 AM
Is it worth while to convert my 1950 3100 from a 6 volt system to a12 volt system
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Coltonk #1342068 01/14/2020 3:56 AM
Here we go again.
Coltonk #1342073 01/14/2020 4:20 AM
You will soon hear both sides of the story here... but in MHO in the long run it is worth it.
Another quality post.
Real Trucks Rattle
Coltonk #1342098 01/14/2020 1:05 PM
Mine is 6 volts, it works well for me, and I have no plans to change to 12 volts.
Coltonk #1342101 01/14/2020 1:38 PM
Yes, this question has been asked hundreds of times here on the Bolt. Do a search using the search button just above your post. Do not use the one at the top of the page. Be prepared for hours of reading. Everyone has their personal opinion and every one is essentially correct for that person. I’ve done both over 55 years of driving experience. Each had its issues both good and bad. For a daily driver my choice is 12 volt except for keeping the 6 volt starter. 🛠
Coltonk #1342110 01/14/2020 2:29 PM
Right now I have a buddies truck in my shop, it is getting a 235 R&R. His is 12 volt, course mine is still 6 volt.
I will know for sure very soon. But I am inclined to believe the starting the engine ignition and starting motor is well served by a full 12 volts, more so if going to a HEI, which seems like a slam dunk if you are going 12 volt in the first place.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Coltonk #1342171 01/14/2020 7:49 PM
Crusing in the Passing Lane
If a 12 volt starter replaces the 6 volt starter(not necessary) then the appropriate 12 volt flywheel needs to be installed.
Ed
Coltonk #1342209 01/14/2020 11:36 PM
I changed my 1 Ton to 12 volts for better headlights. I have reflector headlights with H4 bulbs. They light the road like a much more modern vehicle. They look almost identical to the original sealed beams.
1951 1 Ton Completed
Thanks... I was wondering why I could not get the search results for just a specific forum..
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Coltonk #1342221 01/15/2020 12:26 AM
Yeah, the search at the top is basically a Google search and is useless as far as I’m concerned. The Stovebolt only search is much more helpful when looking for a site specific post(s).
Coltonk #1342232 01/15/2020 12:59 AM
Has anyone installed H4 6v bulbs?
I will try them in my '54 pickup, if it ever gets done.
"6V Motor White Bulbs Car H4 LED Motorcycle Headlight Bulb 56 SMD Hi/Low kit"
"Lumens: High beam: 800LM"
If I put them in my Suburban, I will report back here.
Coltonk #1342264 01/15/2020 4:23 AM
I converted my first very original truck to 12 volts because I grew tired of the "I think I can, I think I can, and then a dead battery" whenever i tried to start it. Not long after the conversiont, the starter quit on me. I had it rebuilt and enjoyed the much faster engine speed when cranking.
The truth of the matter is that if I would have had the starter rebuilt prior to the 12 volt conversion, the conversion would not have been necessary in the first place.
Coltonk #1342286 01/15/2020 12:53 PM
I had the same sequence of experiences, Carl
I had switched to 12v (in the late '60s) because:
- everyone said to do it
- starting/cranking was slow (and getting slower)
Many years later (early this century) after a total restoration:
- cleaned all grounds
- installed correct 6v size battery cables and ground straps (0 or 00 cables & straps)
- installed a Runtz-style voltage reducer into the fuel gauge
- got the starter rebuilt by a pro
That was over 15 years ago.
The only time that I have a problem starting is at night when I forget which direction to turn the ignition switch. dang
Coltonk #1342302 01/15/2020 2:42 PM
For me, switching to 12-volts is right up there with radial tires for my daily driver.
