4 members (jmoore, DaveV, KEVINSKI, Youngin' Tut 59), 129 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
#134182 04/19/2006 7:45 AM
I am looking into a rear end change on my 1940 gmc 1/2 ton. I have already read lots of good information on this sight. I haven't seen any 411 on 6 lug disc brakes. Is there anyway to convert the original axle housing?
I am planning to change the 228 engine to a 302.
Put a dual master cylinder w/disc brakes up front.
replace 3 speed with 5 speed (nv 4500)open driveline
use some axle configuration with a 3.55 or 3.73 ratios
I just want to know before I commit.
#134183 04/19/2006 1:50 PM
1 Offline
give mark at www.scarebird.com a try.if i do recall they use blazer 73-87 rotors.i believe that rotor will work for front and rear. give mark a visit on his website. good luck
