4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#1341309 01/10/2020 3:17 AM
Ok. Im just throwing this out there because this is what happened and found it a bit odd. But hey, everyday is journey i guess. Veh is as many know of as, Frankenstein. 63 GMC 2500 series chassis, 66 Chevy cab and clip, 55/59 9ft stepside bed. Loving it more and more everyday. Anyhow, today was the first day that this veh has made it to the interstate. Lol. All good for a min, the started an upgrade at about 50/55 mph kinda felt something wierd to say the least. Then down hill, all good. Flat, ok. Then started back up another grade and felt like starving for fuel. Got so bad, had to pull over. Slowed and pulled over to the berm. Running, idled, and reved fine. Got out, opened hood, nothing out of the ordinary. But i seen a glare of the oil in the oil bath through the slightest opening at the top where the air would enter the air cleaner. At that moment i remembered putting 10w30 in the air cleaner to the full mark as indicated. Had the carb apart twice, new pump and all back from there, so thought it was worth a try. Pulled the air cleaner housing off, put it on the pass floor, slamed the hood and proceeded up the berm. Yielded on to the roadway, at an upgrade to boot, and all was smooth sailing from there and the next 30 mile circle till home. I wont be using that oil/air filter again. Weather it was to much oil, wrong oil, or God know what, it aint going back on my truck. Morel of the story, Dont overlook whats right in front of you. You might just figure it out. Lol... Sometimes...
Good story. I have heard it stated many times around here and its worth a reminder. Check the easy stuff first. Glad the trip ended well. Looking forward to seeing this truck.
~ HB
1962 Chevrolet C10
1962 Suburban
Hopes of all the stars aligning and your wishes may come true.
You have to take those filters apart once in a while and clean the mesh filter media.
Hmmm. Ill look at it alitta closer . Probably wont use it again regardless. Never had a paper filter put me on the side of the road. Nor in the 3 years or so did my oil bath air cleaner on my 216, disable me.
