6 members (crenwelge, Gray_Ghost, JW51, Cosmo, Lostbuthaulinass, Hugh63c10), 216 guests, and 2 robots.
Topics128,108
Posts1,056,237
Members48,437
#1340298 01/03/2020 8:10 PM
I’m looking at buying driveshafts and a brownie and trans out of a 47 2 ton.
Tag below says it’s a Watson Brown Lipe Spicer model 43M1.
I have searched the interweb and found nothing. I’d like to know what the ratios are inside the box and if seals are available.
Any info is greatly appreciated!!!
When you adapt the box to your frame, be sure to use plenty of vibration isolation material. Brownies, particularly in OD, have a tendency to be noisy. I used to cut squares of big rig tire sidewall material, and stack up a few layers between the transmission mounting ears and the piece of channel iron we used as a crossmember. Metal-on-metal mounting caused a LOT of noise to be transferred to the frame and cab.
Crusing in the Passing Lane
Ford engine mount biscuits, rubber snow plow blade(4" x 1") work well too, some 'brownies' have no shaft seals, just reverse threads to keep the oil in and trash out. One can also put it in various gear positions and count revs. to get ratios, count teeth when apart.
Ed
Ed, I've seen the top tower of a trashed 3 or 4 speed top loader transmission used as a Brownie shifter if the original stick and linkage was not available for some reason. Extending the shift rails and using heim joints made for a smooth-shifting auxiliary stick.
Sounds like a good idea. I pick up abandoned Brownie shift gates whenever I find one since sometimes it is impossible to remove without proper tools.
Ed
Sometimes the "proper tool" is a "Victor Hot Wrench"- - - - - -better known as a cutting torch!
