1 members (baldeagle),
68
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 26 'Bolter | | 'Bolter Joined: May 2016 Posts: 26 | I’m rebuilding a 49 1/2 ton, with stock 216 and drive train, that was mostly apart. Started with the body (panel) and frame. I found a decent radiator that is close to original but has several sets of mounting holes. Aftermarket for sure. Maybe to fit a sedan and/or? Really doesn’t matter. I’m building a driver here. What I’m asking is if someone could post or send a pic of their rad and it’s position in the mount. The vertical position is key but any other info is appreciated. The rad support is in good shape and I think I have it installed correctly. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
