9 members (cmayna, BarryP, Rusty Heaps, DadsFirstPickup, Gray_Ghost, BC59, UtahYork, Peggy M, 1 invisible),
137
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I ordered a couple parking brake cables a while back for my ‘53 framed CDN 1/2 ton. I double checked, and I did order the proper number, but the cable is too big to slip into the frame clamp.
Has anyone else experienced this problem when ordering new parking cables for the AD trucks? | | | | | Joined: Sep 2010 Posts: 512 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 512 | Fox,
I had the exact same problem when trying to replace the park brake cables on my 1953 3100 (US version). The ferrule on the end of the cable simply was too large to fit into the bracket. So I did some very judicious filing with a rat tail file, checking often to make sure that I didn't over file the bracket. Once it was close, a drop of oil helped ease the cable end into the bracket. When I tightened the bolt on the bracket if worked as it should. | | | | | Joined: Feb 2019 Posts: 4,497 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,497 | I had the same issue when I bought my ‘52 3100. The cables ends were just were way too big. I ordered new cables from LMC truck and they fit perfectly. Look at the thread I posted back in in the spring. It has lots of good information. https://www.stovebolt.com/ubbthread...0-emergency-brake-cable.html#Post1308115
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Thanks fellas.
Well, fer mack sake. I guess I gotta go receipt diving to send them back. I tried reaming one of the mounts out and broke it. Luckily, I have a parts truck. | | |
