7 members (Otto Skorzeny, Gdads51, VEW, MickeyP, 50Chevy3100, HandyAndy, 1 invisible), 74 guests, and 1 robot.
Topics128,090
Posts1,056,015
Members48,430
#133942 03/01/2006 10:34 PM
Well I got the new tank from Ebay, it is a 15gallon tank that fits a Jeep CJ. Here is a picture of it hung behind the rear axel of my 1940 1/2 ton. I am happy with the fit. I think I still have good room for the dual exhaust to go past on each side when I get to that. Thanks for the advice you all gave on my post about the tank search. tank picture
Bob
#133943 03/02/2006 9:13 PM
Anonymous
Unregistered
Anonymous
Unregistered
That looks great! Running the exhaust over the springs though is not really a problem. From the shot you have though it looks like it is mounted low. I have mine tucked up right under the bed sills.
#133944 03/03/2006 1:56 PM
Bob, went to your site and got a lot of ideas for mounting my 350 in my 46. Was just curious as I have an S10 front end on my'n and was wondering what type of front end is on yours.The mounts on your 350 are exactly the same as my'n but was wondering what kind of perches they were sitting on. Your doing a great job on your 41.
Bob T
#133945 03/03/2006 7:34 PM
Bobt, My front clip was welded on by the PO but he told me it was from a 1979 Trans Am. I pulled the 350 from a 1987 chevy pickup mounts and all. With the 700R4 transmission still on it I located the position for mounts and rear transmission support. I even measured for the drive shaft and had it cut while I was at it.I also set the cab back on to see if it all would fit then took it all back apart to rebuild the engine and am now ready to start on the transmission. The web page is a new venture to me but I am happy with what I have done with it so far thanks for looking. I might have more detail pictures if you need to see anything more juse email me and ask.
Bob bsodon@cebridge.net
#133946 03/03/2006 9:57 PM
Bob, I wanted one of those full fiberglass front ends for my 39 but when I was ready to buy, it appeared that the only manufacturer that i found(Creative Glass) was out of business. I looked and looked but couldnt find them again.
#133947 03/04/2006 1:09 AM
Stea,
I don't know where the glass front came from but was lucky and got two glass rear fenders as well. The front fenders end at the cab and I have two little short fender pieces that go to the running boards. Now to figure it out!!
Bob
