7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 | I have a chance to buy a C50, but the owner says the rear brake wheel cylinder is leaking. Here is the pic. [img] https://www.stovebolt.com/ubbthread.../filename/00i0i_dM8DCLgHtJk_1200x900.jpg[/img] Does this look like a wheel cylinder leak to anyone. It doesn't, to me. Mod Edit: You can put images directly into your post. CL and Ebay links are only allowed in that Swap Meet forum. The How-To for posting images is at the bottom left of every page.
I usually answer to Todd ---------------------------------- Daily Drivers: 2005 Chevrolet Silverado 3500 DRW 6.6L LLY/Allison 5 Speed 1989 GMC C7000 TopKick Pickup 3208T Caterpillar/Eaton-Fuller 6 Speed
Project Truck (SOLD): 1969 C50 Farm Truck 292c.i. w/SM465 tranny and 2-speed rear
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | You can taste it by taking a finger swipe, then to your tongue, sort of sweet, oil will taste bland. Brake fluid also smells different-open a can to smell and taste and smell, it won't hurt.
Ed
| | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 | You can taste it by taking a finger swipe, then to your tongue, sort of sweet, oil will taste bland. Brake fluid also smells different-open a can to smell and taste and smell, it won't hurt.
Ed Truck is in Kansas and I am in Florida. How could a leaking wheel cylinder leak brake fluid on the outside of a rear dual?
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Ask him how often he has to add brake fluid. A leak that bad needs to be fixed, whether it's a rear hub grease seal or a brake- - - -either way, you're probably looking at a brake rebuild because the brake linings will be saturated, and there's no way to clean them up.
Have you factored in the cost of replacing those widowmaker rims into your offer? The one in that photo is definitely an RH-5 wheel. Jerry
| | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 | Ask him how often he has to add brake fluid. A leak that bad needs to be fixed, whether it's a rear hub grease seal or a brake- - - -either way, you're probably looking at a brake rebuild because the brake linings will be saturated, and there's no way to clean them up.
Have you factored in the cost of replacing those widowmaker rims into your offer? The one in that photo is definitely an RH-5 wheel. Jerry I agree. I still can't understand how it is leaking so badly down the outside of the wheel if it is brake fluid. Just about any truck I find is, most likely, going to have those rims, so it will always be a price factor. Thanks for the info.
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | There is a pretty flimsy paper gasket behind that sheet metal axle shaft cover that is probably the source of the leak- - - -rear end lube, not brake fluid. See if the seller will take some pictures of the inside of the dual wheels- - - - -a brake fluid leak will be dripping down the inside tire as it runs out of the brake drum. Jerry
| | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 | There is a pretty flimsy paper gasket behind that sheet metal axle shaft cover that is probably the source of the leak- - - -rear end lube, not brake fluid. See if the seller will take some pictures of the inside of the dual wheels- - - - -a brake fluid leak will be dripping down the inside tire as it runs out of the brake drum. Jerry Exactly where I would expect leaking brake fluid to be.
| | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 | Okay, I talked with the owner. He said he just washed the truck and that was water, and I believe him. He said the leaking is coming from the drum, on the inside, and is barely noticeable. I can get him to $3500 for this truck and it is the cleanest and most original truck I have looked at, yet. It is a 1969 C50 grain truck, 292, 4 speed w/2 speed rear. No rust! I think I'm going to buy it. Now, to figure out how to get it from the middle of the country down to Florida.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you go get it, allow some extra time to search for a set of wheels, even better, advertise ahead of time, might save yourself a freight trip.
Ed
| | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | If you go get it, allow some extra time to search for a set of wheels, even better, advertise ahead of time, might save yourself a freight trip.
Ed If it's near Great Bend KS, there's a junkyard just north of there that has a bunch of old trucks. You might contact them about wheels. The place is called Nobody's Auto Recycling. Check them out on Street View
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Before you get all crazy about tasting liquid dripping off of tires like that, make sure that a dog has not been nearby lately. Don't ask me how I know. Just so you will know, dog's marking fluid has the exact same viscosity as brake fluid.
| | | | | Joined: Oct 2019 Posts: 15 No Longer a Big Bolt Owner | | No Longer a Big Bolt Owner Joined: Oct 2019 Posts: 15 | Before you get all crazy about tasting liquid dripping off of tires like that, make sure that a dog has not been nearby lately. Don't ask me how I know. Just so you will know, dog's marking fluid has the exact same viscosity as brake fluid.  Yeah, I won't be sampling any fluids. The owner told me he had just washed the truck, and it was water.
| | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Black Jack was the dog's name. Half Doberman, half pit bull. I did not actually do a taste test, but my cousin's version of the story clearly states that I did.
