Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (GMCJammer51, Pre '68 Dave, 1 invisible), 566 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#1338980 12/24/2019 4:03 PM
AD Addict & Tinkerer
I bought a set of used rockers off of fleaBay for my ‘59 235 and the shafts are excessively worn. I see that I can buy replacement shafts but I haven’t seen any where they list different years. Are the shafts from a ‘59 the same shaft as previous models or are the holes in the shaft aligned with the offset groove in the rocker?
Phil
Project Journals
Stovebolt Gallery Forum
' Offline
Rocker Arm Shafts are the same for 1940 to 1962 Chevy 6 cylinder engines .
GM # 0.353 - GM # 3836138
There are two rocker shafts on ebay .
Go to ebay & in the search box type.............3836138
Llewellyn GM Obsolete
Northridge , CA.
phone : 818 - 363 - 5094
Llewellyn has ( 1 ) GM NOS rocker shaft in stock
Here's a PIC of NOS rocker shafts that I purchased back in 2007 .
https://i.postimg.cc/rFftcj5C/Rocker-Shafts.jpg
These are getting scarce in GM NOS .
PIC
https://i.postimg.cc/fWgQMjGc/235-Chevy-Rocker-Shafts-GMNOS.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Here is a rocker arm rebuilding service that may be helpful. http://www.rockerarms.com/pages/gm.html
I have used them for rocker arm rebuilding and they are excellent. Not inexpensive but when they are done with them, they are right on the money. No wobbling, oil leakage, nice new adjusters.
Mike
Thanks for all the suggestions. The rockers seems to be in good shape so all I want to replace is the shafts. My concern was the shafts being all the same thru the years. I checked the existing shaft and the holes in the shaft don’t align with the offset grooves in the rockers, so I want to make sure that is correct of a ‘59 235 before I invest more money into the assembly.
Phil
Project Journals
P Online: Content
The 1959-62 rocker grooves will not line up with the holes in the shafts.
This is the way Chevrolet restricted the flow.
My Blog
Thank’s that is the answer I was looking for!
Phil
Project Journals
It’s not that the rockers are in good shape, is the clearance between the shaft and the rocker. It’s important on the 59-62 version because if it’s a little out of specification, the oil pressure bleeds off around the rocker and because the 59-62 rocker has the off set groove, if the pressure is bleeding off around the rocker then the rocker does not get sufficient oil. Just check it carefully.
Mike
I’ll have to check the clearances but when I removed the rockers from the shaft, every place the shaft wasn’t worn, it tightened up nicely. Do you know what the clearances should be?
Phil
Project Journals
I have a set of new shafts and rockers under the bench, when I go out there today I'll try and run some clearances
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
The rocker arms are much harder than the shafts. It sounds like yours will be fine with new shafts. Been there, done that. They were out of t-shirts.
Carl
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.061s Queries: 15 (0.058s) Memory: 0.6427 MB (Peak: 0.7477 MB) Data Comp: Zlib Server Time: 2025-09-22 12:41:17 UTC
Valid HTML 5 and Valid CSS
