6 members (John Dlugos, Otto Skorzeny, Gdads51, Oswald, 216wny, 1 invisible), 168 guests, and 3 robots.
Topics128,101
Posts1,056,179
Members48,436
#1339029 12/24/2019 8:49 PM
Did a thorough wash and rinse then applied NuFinish according to the directions. Buffed off the haze as the instructions said. Ended up with a dull hazy but smooth finish that will not polish out by hand or with a power buffer. The paint is old but did not have a rough finish and was smooth to the touch prior to and after the application of NuFinish.
What is the recommended procedure for removing the product and returning to the unwaxed state.
If me I’d try carnauba wax (Mother’s) on a small area over the NuFnish. I’ve used NuFnish long ago and don’t recall any issues. It’s silicon based?
A good cut/buff will do a world of good if the right person does it.
Good Luck
RonR
RonR
1970 340 Duster
1964 CJ5
It does not seem to be silicone based:
"Calcined flint clay"
It looks like it is silicon based.
7
7 Offline
PPG Wax and Grease remover.
Ditto the use of a wax and grease remover (I also splashed some on my daughters highly polished, red, fender when cleaning years of accumulated grime on her hood underside and it completed stripped the wax down to the dull red finish prior to the car being detailed before she bought it. You might try it on a spot to see if it works. It was on the fender for 15 minutes or so and I did not touch it.) It sounds like the finish was oxidized when you initially waxed and it seems as though most car waxes today are "clear coat safe" meaning pretty mild at removing oxidation. Imagine you will need to use a polish/cleaner product to remove the oxidation (or buff the finish out completely) and then use NuFinish, carnauba, etc to enhance your new shine.
As a follow up, I used wax/grease remover and it barely loosened anything. Granted I did not let it soak the surface. Tried Maguires Ultimate Compound and it removed the NuFinish but still left a slight hazy look to the paint. Afraid a cut and buff is in my future. Thanks for the ideas.
