10 members (Lightholder's Dad, Hanks custodian, Otto Skorzeny, Gray_Ghost, MickeyP, mick53, Gdads51, KCMongo, JW51, 1 invisible), 95 guests, and 2 robots.
Topics128,049
Posts1,055,658
#1338429 12/20/2019 3:42 AM
1 Offline
hello , i have a 1.5 ton chevy dually with a dana 70HD rear end with disc brakes and a sm 465 standard transmission . i have been searching for some type of emergency brake
to fit this set up . for the disc brakes my rotors are to thick 1 1/2 inch thick and the current calipers do not come with emergency brakes available , nothing i have found will fit . a
transmission brake , i have not found one yet . currently i have a
hydraulic parking brake i am not to crazy about . what about a pinion emergency brake ? and what type of emergency brake is excepted for general road use in all the USA ?
thank you 1pete1
There's also the fits all E-brake.... wheelchalk. drive
Along with the hydraulic lock you mentioned, it shouldn't roll away.
Tow trucks use hydraulic locks all the time. As long as everything is, "UP TO PAR", I would trust it. JMO
3B Offline
Hy 1pete1, I still have the parts I told you about two years ago.
I like a drive line E-brake on larger vehicles since the braking force is multiplied by the rear end ratio. A drum at the transmission or a rotor on the pinion will hold a loaded truck, even in reverse.
Evan
Crusing in the Passing Lane
E brakes come on 465's, so look around for one, could be on larger truck that does not have cable E brake on rear, 1.5 ton truck for example, might have larger input shaft, but brake should work.
Ed
Big Bolt Forum Moderator
If looking for a park brake off the back of an SM465, you might try Ron's auto wrecking over near Purdy. He had quite a few bigger trucks in there last time I was in there. Not sure if he'd have one or not, but he may know where to find one!
http://ronsautowrecking.weebly.com/contact-us.html
Mike
Try to Google " manual brake caliper" you'll find a lot of stuff, also try Pirate 4X4, they seem to have looked at this. Wilwood makes some they call spot calipers, I think. there are a lot of industrial application units that could work but they are pretty big. Remember that if a caliper is bolted together you can usually make it any width you want with spacers.
1949 3100
