8 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50),
73
Mod | | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hello , i have a 1.5 ton chevy dually with a dana 70HD rear end with disc brakes and a sm 465 standard transmission . i have been searching for some type of emergency brake
to fit this set up . for the disc brakes my rotors are to thick 1 1/2 inch thick and the current calipers do not come with emergency brakes available , nothing i have found will fit . a
transmission brake , i have not found one yet . currently i have a
hydraulic parking brake i am not to crazy about . what about a pinion emergency brake ? and what type of emergency brake is excepted for general road use in all the USA ?
thank you 1pete1 | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | There's also the fits all E-brake.... wheelchalk.  Along with the hydraulic lock you mentioned, it shouldn't roll away. Tow trucks use hydraulic locks all the time. As long as everything is, "UP TO PAR", I would trust it. JMO | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1pete1, I still have the parts I told you about two years ago. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I like a drive line E-brake on larger vehicles since the braking force is multiplied by the rear end ratio. A drum at the transmission or a rotor on the pinion will hold a loaded truck, even in reverse.
Evan
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | E brakes come on 465's, so look around for one, could be on larger truck that does not have cable E brake on rear, 1.5 ton truck for example, might have larger input shaft, but brake should work.
Ed
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | If looking for a park brake off the back of an SM465, you might try Ron's auto wrecking over near Purdy. He had quite a few bigger trucks in there last time I was in there. Not sure if he'd have one or not, but he may know where to find one! http://ronsautowrecking.weebly.com/contact-us.html | | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | Try to Google " manual brake caliper" you'll find a lot of stuff, also try Pirate 4X4, they seem to have looked at this. Wilwood makes some they call spot calipers, I think. there are a lot of industrial application units that could work but they are pretty big. Remember that if a caliper is bolted together you can usually make it any width you want with spacers.
1949 3100
