13 members (Gray_Ghost, FAST55, 1955 1 Series, GusG, Bill Hanlon, sron48, Wally / Montana, Stovebolt48, JW51, GrandpasJimmy, tclederman, ‘37ChevyPU, 1 invisible),
71
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 52 | I have a '48 GMC 1/2 ton. It has a 4 SPD trans but the smaller 9" clutch assembly. I understand that someone may have swapped in the 4 spd at some point. Was the smaller clutch just used on 3 spds or some 4 spds as well? Will the smaller clutch be ok? I won't be towing with it. | | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | If the 9" is working it should be fine if everything is stock. I think the larger clutch requires a different flywheel, the bolt pattern is different and the wear surface is also different.
1949 3100
| | | | | Joined: Jun 2018 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 52 | The truck wasn't running when I bought it and hasn't yet. I pulled the trans to check the clutch which I am replacing. I was just curious if anyone had any solid information on the subject. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | If the trans, pressure plate and clutch are out, measure the machined face of the flywheel and the size of the pressure plate. Its probably larger than 9. 55-57 used a 9.5 but the flywheel was actually machined enough to be able to use a 10.00. GM apparently gave us 6 guys the short shrift and used a smaller clutch but a 10 inch clutch and pressure plate will fit. You might find the same with yours. Four speed truck commonly came with 10.00, some with 11 so take a look and see what the flywheel will accommodate.
Mike
| | | | | Joined: Jun 2018 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 52 | My truck is a '48. The machined surface of the flywheel is 9" which matches the clutch and pressure plate. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Bigger is not always better. A smaller disc makes shifting easier & is better for the syncros in the trans. As long as it can handle the torque of the engine & the driver knows how to use a clutch. The syncros have to slow down or stop the disc & gears in the trans.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1/2 ton trucks standard size with 4sp is 9", heavy duty available with 10-3/4". Heavy duty requires flywheel with 9 mounting bolts for the pressure plate, instead of 6 for the standard duty. Believe 3/4 and up trucks got the bigger clutch 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jun 2018 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 52 | | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hi GTOKID, Just my 2 cents, but don't put a 10 3/4 clutch in as they're way expensive $$$$$$$$$. Carters and 40's carry them and all you have to do is look at the prices for each piece as they have to be rebuilt. I have a 1.5 1946 and have changed the clutch twice, once after buying and once because the disk rusted to the flywheel. Since your truck is a 1/2 ton, I'd put a 10" or 11" in where you can buy clutch kits all day long provided your flywheel will take the bigger pressure plates, but even then its no biggie to replace that. Just a suggestion, Good luck. | | |
