3 members (cmayna, BC59, Wickedbass), 51 guests, and 5 robots.
Topics128,086
Posts1,056,101
Members48,434
#1337765 12/15/2019 10:54 PM
Hello guys Tom here,
I have a 1955 270 motor and would like to mount a 12 volt alternator on it any thoughts on make or amps will be appreciated old dog
Riding in the Passing Lane
A Delco with the internal regulator about 55 or 65 amps would work.
George
1972 Chevy c10 Cheyenne Super
Insomniac
Insomniac
Here's a great article I found helpful...
http://www.madelectrical.com/electricaltech/delcoremy.shtml
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
Thanks guys, thats lot a info old dog
I have a 6V from this guy and it works fine. In general with all his recommendations for an alternator, does the old 216 wide belt pulley fit a modern alternator?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
AD Addict & Tinkerer
If not, you can obtain a 5/8” pulley from Speedway. I used this one on my 10si 63 amp alternator.
Phil
Updated to: β€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
Nice! Thanks
1946 1-ton Panel
Have to correct myself. I got my 6V alternator form this guy. https://www.ebay.com/str/HowardEnt?_trksid=p2047675.l2563
1946 1-ton Panel
I bought an alternator conversion bracket which you will need from the Car and Truck Shop. The bracket slots where it bolts to the block were too small for 3/8” bolts. Having a lathe with an milling attachment made enlarging the slots easy for me, but I assume there are brackets you can buy that would fit without modifications. Once modified the bracket and associated tension bracket worked great.
Maybe other β€œBolters” could chime in as to their experiences with alternator brackets and where they bought them from.
Phil
Project Journals
DLBrooks
DLBrooks
Take the wide pully off the generator and put on the alternator - 10si no problem - 12si you may need a spacer. And you can easily make an alternator bracket out of the old generator bracket if you are a fabricator/welder. I suggest using a 3 wire alternator - internal regulator - as you can kill the alternator connection to the battery with ignition switch off.
1959 GMC 100 Fleet
Follow in the DITY
Sir Searchalot
Sir Searchalot
Old dog............ just get a standard 10si internally regulated alternator. Pretty cheap. Mounting is a little fab work probably. It sure does get rid of a lot of electrical junk and wiring. I advise not to get a 1 wire type. We can help with wiring, no problem.
Does anyone know what RPM the alternator is supposed to turn at idle? Is it the same as what a generator is supposed to turn?
Alternator pulleys have a significantly smaller diameter than what a generator pulley has.
Crankshaft pulley diameter has an impact on this situation as well.
That's one of the big advantages of an alternator- - - -it can turn several times as fast as a generator without damage. The way the rotor is wound allows the alternator to turn 3-4 times engine speed, or more, which would throw the windings out of a generator armature. That's why an alternator can charge a battery at idle speed- - - -something even a 12V generator was hard-pressed to accomplish. A 6V system usually puts a slight drain on the battery unless the vehicle is driven several miles at highway speed every time the engine is started.
DLBrooks
DLBrooks
I agree that an alternator can charge at idle but a 10si one wire does need excited which is usually about one time to 1000 rpm. So the choke on may get it excited but also may take a rev to excite. Also the one wire will draw about .003 amps even with key off. Not much draw but if stored and with no trickle --it will discharge.
A 3 wire uses the key to exite the diode -- so excited when turned on. Plus the key completely disconnects the diode from the battery.
One wires are for tractors but are cheap and will work on trucks.
1959 GMC 100 Fleet
Follow in the DITY
