7 members (TUTS 59, Peggy M, Gdads51, 68ironhead, tclederman, 2-Ton, wilbur53),
154
7
Mod | | | Forums66 Topics128,281 Posts1,058,476 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | Just asking- how hard is it to rebuild the Ranco valve? I’m weighing the cost of having it done ($150 if you have one to send them) or rebuilding it myself. I saw Dave’s descriptions and they look pretty complete but just want to hear if it’s harder/easier than it looks. | | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | Very easy to rebuild, You only replace the rubber stopper and some kits give you a new plunger, but is not needed . Just take your time taking apart ,has brass lock down tabs ,once straight you just wiggle and pull and it will come apart, Also the new seal only will cost you 10 to 20 bucks. Napa sells them. Have fun very easy
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | Thanks. Looks like you have to be very careful re-assembling it. Any “tips” to look out for from previous repairers? | | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | Another question–– where/how does the capillary tube attach? There is a small bracket on the end of the tube with a hole in it, I assume for a screw. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The cap tube is supposed to measure the temperature of the air exiting the heater as you probably know. IIRC the tube on mine was screwed to the cardboard firewall pad adjacent the air outlet. It worked well. I repaired mine years ago with a kit specified for a 70s era Volvo. It was cheap and easy. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Dec 2013 Posts: 795 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 795 | I rebuilt my Ranco valve a few years ago. Achipmunk sent me a few photos that really demonstrated the process, but I couldn't locate them. A quick search and I found this step-by-step Ranco valve rebuild by Czechman aka 'Woody'. This gives you a pretty clear picture of what you are in for and it is quite doable. RANCO VALVE RESTORATIONI may even have another seal or two BK 660-1000. Send me a PM if you're interested. | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Don't tell tclederman, but I completely disassembled my leaky Rancho valve, including unsoldering the end cap to facilitate the complete gutting of the internals. I then reassembled it so that it is nothing more than a solid, leak-proof pipe fitting. I still have the now non-functional bellows in place as well as the "warmer" knob which still turns, but doesn't do anything. It now works just as well as the originals did. Not at all (in my opinion).  And it will never leak again, which is more than can be said about the original ones. Carl
| | | | | Joined: Sep 2010 Posts: 2,354 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,354 | Could a newer type valve be used or modified to work as the original with the turn type knob instead of a cable. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Mine worked fine and kept the temperature constant, up hill and down dale unless I moved the "warmer" knob. Kept the cab toasty down to about 10 deg. F. Then cardboard had to be put in front of the radiator and a 195 thermostat but even that was marginal below zero. We're moving into that kind of weather now where I am. Seven degrees this morning. The later deluxe heaters had a door on the front that could be opened to recirculate the air in very cold weather. I passed one by in the junk yard years ago and have regretted that many times. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
