8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible), 106 guests, and 3 robots.
Topics128,134
Posts1,056,740
Members48,454
#1336386 12/04/2019 2:20 PM
Hello all,
Preparing to replace the Intake and Exhaust manifolds on my 46 235. someone has placed a later day 235 manifold and intake on the engine.
I got a new repro exhaust manifold from Carters and a used 216 intake plus new alignment rings. Were the holes for the alignment rings for the
intake and exhaust manifold the same for 216/235? Also, could someone tell me the length, size, and total number of new studs I will be replacing?
I will also be replacing the alignment pins with bolts, does anyone know the exact length of bolt I will need? The truck is some distance away so I'm
wishing to have everything I'll need on hand upon arrival for the job.
No, the diameter of the "holes" were not always the same.
MT used to sell adapter alignment rings.
He will probably also know (and, have) the correct length/number of head bolts.
You can Private Message : Mother.Trucker
1941-49 235s used the same alignment rings as 216s.
My Blog
Just asking here but any particular reason why you are changing the factory alignment pins out for bolts? I ask because that design was well sorted out and used for several decades up through 63 and is not a common problematic area. Also, consider using a Rimflex gasket when you do your reinstall. Excellent gasket for our beloved motors.
Mike
I second the recommendation for Remflex manifold gaskets. I've used them twice now on 235s, both with excellent results on manifolds that had pretty bad misalignment between the intake and exhaust surfaces. About $50 for a Remflex got me going again without the time and expense of having the manifolds machined.
1953 3600 Pickup
1946 Fleetline Aerosedan
1948 Hudson Commodore
Upon looking a close up pic of my engine, the alignment pins have already been replaced with bolts, wanted all new stuff before I make the trek to work on it.
Who sells the Remflex gasket? What so special about them versus Fel-pro or the other common brand?
GMC sixes of that vintage used bolts rather than screws at the ends - their heads were different (and a little longer).
Remflex and other sources.
Consider installing some original alignment pins. The end clamp on the intake, the long one with the short clamp, is more then sufficient to keep things in good order for the end ports, especially with the Rimflex gasket. With bolts installed on the ends of the exhaust manifold, you may run into trouble with cracking the casting. The assembly is aligned by the end pins and the intake rings. Attachment is by clamping force.
Mike
Remflex gaskets are very thick--much thicker than stock-style manifold gaskets, and they compress significantly when you torque down the parts. This allows for unevenness on the mating surfaces that would lead to failure with standard gaskets.
1953 3600 Pickup
Can anyone tell me the length of the intake and exhaust studs/bolts on my 46? I want to have new stuff ready to go. I ordered the Remflex gasket yesterday and will have my Fel-pro as a backup as I saw the Remflex are easily broken.
Easily broken? No. Unless you fold it in two, lol. You will be just fine with the Rimflex and even better when you have no leaks.
Mike
Crusing in the Passing Lane
Hold your manifolds up against the engine, add nut, lockwasher dimension, add .250", add manifold dimension, add all up.
Remember to snug up intermanifold bolts, tighten manifold bolts, then tighten intermanifold bolts last.
Ed
Thanks Ed, I actually went to Carters Friday and laid my hands on some used intake/Manifold bolts to use a guides from new stuff.
