| | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 5 New Guy | | New Guy Joined: Aug 2019 Posts: 5 | I did check the 9 pages of other threads before posting so I apologize if this has been hashed out.
I am building a 1950 on a 2001 S10 frame, when I dismantled my donor I kept all the brake lines master cylinder and brake booster. The guy I was buying from had a smaller booster and brake pedal installed on the truck. Per part number the booster appears to be from a 1993-2002 Camaro\firebird.
Even though this is my first ever build, I do understand that the engineers design all the brake systems taking a variety of things into consideration. I am using the front disk set up and the rear drum set up from the 2001 s10. My question is how interchangeable is this brake booster and master cylinders? Can I use any brake booster that fits with my S10 master cylinder as long as I can get the pedal travel correct? is the proportioning valve the most important piece?
The bolt hole pattern is different so I am trying to use the holes already cut in the firewall, plus I like the idea of the smaller booster. I am not using any of the antilock stuff.
Anyone have experience with this or a resource that might help? Thanks in advance.
