Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 546 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
I
I Offline
Does it matter where the distributor points as long as the #1 plug wire is going to the #1 cylinder? Would the engine run if #6 was at TDC and the plug wires were set up 180 off so they #1 wire still was on the #1 cylinder?
1949 3600 216 4 speed (completely original)
The important thing is to determine which cylinder is on the compression stroke. Both #1 and #6 pistons reach TDC at the same time- - - -only one is at the top of the compression stroke, ready for the spark plug to fire, and the other cylinder is at the top of its exhaust stroke, ready for the intake stroke to begin. I like to watch the valves on the #6 cylinder- - - - -as the #6 exhaust valve closes, and the intake begins to open, #1 is on TDC compression. Point the rotor to the #1 plug wire, and set the distributor housing so the points are barely open. The engine will start every time!
Yes as long as the rotor is pointed to the wire going to number one when it is at top dead center the position on the cap is irrelevant, although the wires must be in the correct firing order..
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I
I Offline
Ok started from scratch and know that I was TDC at #1 with both valves closed and timing mark pointed at the a hole in the flywheel. Not the BB on mine but a hole. When I rotate engine one revolution to TDC #6 now I see the BB. All I know is valves and pistons are correct for both 1 and 6 even though marks don't sound right.
Any thoughts on this, does this sound possible?
I moved my wires so rotor is at about 6 o'clock with matching plug wire is going to #1. Distributor clamps are parallel to engine. It started but was barely running. I'm going to do a static timing to see if I can get it closer tomorrow.
Both valves will be closed when either #1 cylinder or #6 cylinder is lined-up on that mark/ball.
The Stovebolt-six crankshaft moves two full revolutions for one revolution of the crankshaft.
So, yes, that mark/ball indicates 1 or 6.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.228s Queries: 14 (0.045s) Memory: 0.6101 MB (Peak: 0.6570 MB) Data Comp: Zlib Server Time: 2025-09-22 07:46:05 UTC
Valid HTML 5 and Valid CSS
