| | | Forums66 Topics128,108 Posts1,056,566 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 13 New Guy | | New Guy Joined: Mar 2017 Posts: 13 | Greetings! Just replaced the column shift in my '62 to a floor shift. However, my transmission hump is too low. I need the high hump pan to accommodate a 3 speed floor shift. I've been searching on line but have yet to find what I think I need. I'm sure several of you guys have been through this. Any suggestions? Thanks in advance and Happy Thanksgiving! Doug Robertson [email protected]
1962 C10 shortbed
| | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | I got lucky when I found mine in an old junk yard about 13 - 14 years ago. There is a section of the firewall that you will need as well. Once you look at that area in the firewall, it will be obvious where to cut the spot welds and pull the piece out. The rear part of the High Hump is a direct bolt in, but the front needs the matching piece that is welded onto the firewall.
The previous owner had swapped out the 3 Speed for the SM420 4 Speed, but did not change the tranny tunnel. They just bent a piece of sheet tin over the area and screwed it down. Ugly solution! I had to fix that. | | |
