| | | Forums66 Topics128,110 Posts1,056,257 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | I have a 1952 Chevy pickup half ton short bed. It is outfitted with turn signals and 4 way flashers. My tail lights contain 2 bulbs each, my blinkers and brake lights line up on the bulls eye (bottom bulb) when active, and the tail light lines up with the bulb at the top. My question is this the the right set up?
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | 49/3100 Mine are the opposite, park on bottom, turn and brake on top. Not first owner so really don't know if correct. Works for me.
Ed
| | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | Forty9 is right. The running lights also light up the license plate. That bulb needs to be close to the clear lens (in the left taillight) on the bottom.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The heaviest(brightest) filament is for turn and brake lights, smaller filament is for running(license plate) lights.
Ed
