| | | Forums66 Topics128,205 Posts1,057,429 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 33 Junior Member | | Junior Member Joined: Feb 2005 Posts: 33 | Hey everyone, I just built myself a little gen 1 small block chevy now built to 353ci. the block is from a 1974 monte carlo. and the heads are GM aluminum heads from an 1986 corvette. I have after market pulleys that use a trick gilmer belt drive, they are designed for standard rotation- standard flow cooling. in 1986 the corvette had reverse flow cooling by changing the design of the water pump and spinning the pulley in reverse direction of the crank. I had to fix some cracks in both of these heads because I believe someone used these heads with stand flow cooling.... is anyone familiar with a standard rotation reverse flow water pump either short or long style...? thanks ~Mykk | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Well, I'm pretty sure it wasn't until the LT-1 350 appeared in the Corvettes that they became reverse flow. In 1986, the 350 in the Corvette was still the L98 tuned port engine, and that wasn't reverse flow yet. I'm pretty certain about that, but I can probably find out.
My son has an LT-1 powered Trans Am parked at my house while he's in the Navy. So I have a visual reference at my disposal. What is it that you need to know about it?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yeah, it wasn't until 1992 that the LT-1 replaced the L98. Here is the website I found that information at: http://www.idavette.net/hib/c4hib.htm The dates are fuzzy, but the L98 started out with a hydraulic flat tappet cam and iron heads, and made 230 hp, but a BUNCH of torque. The mild cam and tuned port runners didn't allow much power above 4400 rpm, which is what limited the hp number. Then the L98 got aluminum heads and higher compression, and went up to 240 hp, I think that was 1987. Then the L98 got a hydraulic roller cam and was good for 250 hp. That stayed until 1992 when the new generation small block 350 with the LT-1 intake and reverse cooling configuration made its debut with 300 hp. It made less torque than the L98, but had much better top end power thanks to its new 6000 rpm redline. It's a little trivia but it's interesting. If you can get ahold of that torquey L98 tuned port injection, it would be fantastic in a truck!!!
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | All L98s are standard SB1s. That said, those heads aren't the greatest things out there. Nice, if cheap, but the flow is pretty constricted. I'm converting a set of cast-iron LT1 heads to standard flow for my Vette, but that's a different kettle of fish. | | | | | Joined: Feb 2005 Posts: 33 Junior Member | | Junior Member Joined: Feb 2005 Posts: 33 | Thanks for all the input, I was under the impression that all reverse rotation water pumps had to flow reverse... but I've heard from a number of sources that my aluminum L98 heads are standard coolant flow, wich makes my aftermarket application a whole lot easier.. thanks for all the input. | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | reverse rotation pumps are used for serpentine belt setups
2003 ford lightning 1959 chevy 36
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You CAN get your L98 heads to flow well. Have a machinist blend the bowls and do a good 3 angle valve job at least, or even better, have him radius the valves.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | OK, I was under the impression that the "reverse flow" meant the water went thru the Heads first and then thru the Block, there's the little piping on the back of those LT1 heads, I believe they're bleeders for air pockets because of this flow direction... | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | well there is reverse flow cooling that ls1 and i guess lt1 motors use. that is like what you just wrote as in the coolant flow direction is reversed, heads block then radiator.
then there are reverse rotation pumps for serpentine belt systems on non-rever FLOW motors. with a serpentine system, the water pump pulley rotates in the opposite direction than that of a v-belt setup
