4 members (Otto Skorzeny, Jon G, JacobU66, 1955 1 Series), 69 guests, and 1 robot.
Topics128,026
Posts1,055,399
Members48,422
#1333592 11/13/2019 11:43 AM
PA OUTLAW
PA OUTLAW
has anyone used jim carter wiring harness. what do you think? do you know a better suppler working on 1954 chevy 3100 with hyd-matic tranny witch means push button starter &netural safety switch also it will be 12 volt what do think? A BIG THANK YOU IN ADVANCE!!!!!!!!!!!!!!!!!
jrhackett #1333595 11/13/2019 12:45 PM
Jim Carter (and Classic Parts and Chevs of the '40s) 1954 "reproduction" wiring harnesses are almost the same. They work very nicely in 1954 3100/3600/3800 trucks.
The wires have plastic-coated wiring (as in 1954) and the are the correct 6v gauge (and the correct colors). 6 volt gauge wire will work fine with a 12v electrical system (which works with thinner gauge wire).
Only custom-made harnesses will have the extra leads used with a Hydra-Matic transmission. You will have to make those leads/wires.
jrhackett #1334077 11/17/2019 2:55 PM
I used Rhode Island wiring for my 40’s 1/2 ton and they did an awesome job. Wire color, size, terminations and length were all the same as the old factory harness and price was the same as most other “big box” stores. Plus they will add into the harness anything you need or want.
44 Canadian chevy 1/2 ton
jrhackett #1334561 11/21/2019 2:02 AM
8
8 Offline
I installed Jim Carter's cloth covered wiring kit for my 1948 1.5ton Loadmaster five or so years ago. I have had no problem with it, and installation was pretty straight forward.
Curt
Curt Warren
Salt Lake City
http://photobucket.com/48loadmaster
