BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,781 Posts1,039,299 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Nov 2007 Posts: 94 Shop Shark | Shop Shark Joined: Nov 2007 Posts: 94 | Hi there, I have a C30 that was ordered from the factory with a 1.5 ton ten bolt "P30" style front end. Only thing is that it has drum brakes and a single circuit system. I want to convert the front end to disc brakes and upgrade to modern "non-split rim" type wheels.
I have heard that modern C30 or "3500" spindles and disc brake equipment are almost a direct bolt-in affair. I am just not very familiar with what parts would interchange.
I want to swap to a dual circuit master cylinder with a vacuum assist booster, swap to disc brakes up front and modern dually wheels all around.
Can anyone point me in the right direction for another post on perhaps someone has done this conversion already?
Thanks Kevin I am in Culpeper, Va. | | | | Joined: Apr 2005 Posts: 7,442 Bolter | Bolter Joined: Apr 2005 Posts: 7,442 | Read the thread at the top of this forum page.
