7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#1331117 10/25/2019 1:37 AM
Hi all my first post and my first Stovebolt 48 gmc firetruck with a 270 I know this from the only number on the boss is 270 and by measuring the bore. Tuck has been sitting 20 + Years couldn’t get it to start After a compression test I found low compression to be the culprit. #2&4 has 0 the rest had 30. Removed the head found the seats to be pounded and rusted out. Sending head in for a complete rebuild. Upon inspection of the engine #4 cylinder had a small patch of rust. A ball hone was used on the top 3/4 of the cylinder and it came out pretty good. Now the only other issue is I have 3 lifters with some galling on the cam face Dose any body know where I can get three new lifters? Thanks and I can’t wait to hear from you guys
Ford351 #1331126 10/25/2019 3:11 AM
' Offline
If you find ( 3 ) new lifters .
Do you think that will fix the damaged cam lobes ?
Sounds to me like you need to get the camshaft reground
and the lifters refaced if that's even possible .
Usually galling goes deeper than refacing can fix .
You can bet the cam lobes are damaged if the face of the lifters are galled .
https://egge.com/info/lifter-resurfacing/
https://www.triumphexp.com/forum/sp...e-lifters-without-replacing-cam.1253035/
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Ford351 #1331194 10/25/2019 6:59 PM
There is a new GMC camshaft on Ebay for $270.00. The same "milk can" solid lifters that work on 216's and 235's also fit GMC inline six engines of all sizes. Those are available on Ebay also. If any of your lifters are junk, so is the cam.
Ford351 #1331212 10/25/2019 9:30 PM
Crusing in the Passing Lane
Delta cams in the Seattle area does cams and lifters, too.
Ed
Ford351 #1331224 10/25/2019 11:43 PM
They do nice work (Delta) and can recondition the lifters if I they are in ok condition. Ask for a mild 3/4 cam grind. Might as well inspect bearings.
1946 GMC Project
"Back-in-the-day Restore"
Ford351 #1331287 10/26/2019 2:10 PM
' Offline
I just read a few very negative posts about Delta cams
on the internet . They seem to have a problem of losing
camshafts on customers .
I'd try , Oregon Cams
http://www.oregoncamshaft.com/
You'll need a full set of ( 12 ) " Chilled Iron Base " Lifters for
your FORGED STEEL CAMSHAFT .
No other look a likes will be metal to metal compatible .
Stay away from any recently made lifters or made in china junk .
On ebay , there's a full set of aftermarket lifters made way back when .
They are made in the USA by a very good quality aftermarket company ' Wohlert's ' .
They are old time aftermarket lifter replacements for the original GMC
" Chilled Iron Based "....Lifters......GMC # 2194006 .
Go to ebay & type in the search box..........2194006
A set of Wohlert's lifters will show up @ $150.00 for the set of ( 12 ) .
PIC
https://i.postimg.cc/cHy68xYc/GMC-Wohlert-s-Lifters-replaces-GMC-2194006.jpg
Then you can send your cam out to be reground .
If you are serious about getting your engine running again . I would not pass up the chance to get
these old time scarce lifters .
These " Chilled Iron Base " lifters CANNOT be used with any cast camshaft .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Ford351 #1331288 10/26/2019 2:28 PM
I have been using them for close to forty years, they are about 10 miles from me. I just had them ground a 261 cam for me and surface all my solid lifters, cost me $150. Be very careful on how you read the nay sayers on the internet. These guys have been in business doing good work all across america for at least 1/2 century. They know their stuff and I have 100% confidence in them. About 5 years ago, they moved their operation down the street 4 blocks. They had a lot to move and many cores and machines, sure I bet a few things got misplaced. If you are that worried, send your stuff to me and I'll personally take care of it. I live in the pacific northwest and never heard of Oregon Cams.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
